You will need to give more background. What commands are you using to generate views? Are you using AutoCAD or a vertical?
If you are using the sectionline/sectionplane command, then select the sectionline and choose boundary or volume. Adjust the extents of the section boundary and then draw the section.
After you place the section view, select it then Edit View. You'll be able to choose between FULL, SLICE, and Distance
See 01:03:00 in the Autodesk University screencast below for additional clarification
(AU online is free, just use your forum username/password if asked to log in)
AC:2359 Inteligent AutoCAD Model Documentation Made Easy
