Hello All,
I would like to know where I can set my default files location in ACAD2014. When I click open (ctrl-o) it will search in that location only. I know it store previous files, but if I want to look in the main folder, this is what I want to setup.
Thank you
KenJG
Solved by pendean. Go to Solution.
maybe the sysvar REMEMBERFOLDERS (>>>details<<<) is a help?
- alfred -
"...if I want to look in the main folder"
If you use a desktop shortcut to launch AutoCAD, edit the shortcut's "start in" location to point to that folder. (You might have to create your own desktop shortcut to be able to edit it - the one AutoCAD places there during installation may not be editable this way.) You can edit the shortcut if the location changes, or you can make as many shortcuts as there are folders you would like to be able to start in.
Another option is to always launch AutoCAD by opening your "main folder" in Windows Explorer and dbl-clicking a DWG file located in that folder.
