Hi! After subtracting solids of different colour my original solids now have faces that are of a particular colour, not "ByLayer" as the solids themselves. I wonder whether there is a quick way to change colour of all faces on a lot of solids to "ByLayer"? Thanks in advance!
Solved by nestly2. Go to Solution.
I believe it only happens when there are manual color overrided applied to the object(s)... right?
Select the multi-color solid and change it's color property, then change it back to "ByLayer"
