Hi there,
I had an issue with my windows profile that was resolved by recreating a new copy one.
I've got Civil 3d 2012 and Civil 3d 2014 on workstation installed.
By mistake i've opened the 2012 version first and windows associated all the .dwg and other extensions with the 2012 version.
But i need to use the 2014 because of the aecobjects are with that version.
I tryed :
Right clicking and selecting the default program, choose the 2014 one. But windows doesnt seem to keep that selection.
I've even tryed repairing my installation of Civil 3d 2014 ( http://forums.autodesk.com/t5/AutoCAD-2013-2014-2015/Set-AutoCAD-2015-as-default-for-opening-a-DWG-b... )
I'm going short on ideas here ...
Anyone has a suggestion ?
Solved by pendean. Go to Solution.
You have a shortcut for both versions. Open 2014 with a blank drawing, then use OPEN menu to open the drawing you desire. From there on all drawings should open with 2014. That works here.
In Windows Explorer right-click on a dwg file and select Open with then Choose default program. Mine is set to use AutoCAD DWG Launcher and it always sets the last program ran as the default for opening dwg files.
