AutoCAD 2013/2014/2015
Distinguished Contributor
m.granata
Message 1 of 21 (2,739 Views)
Service Pack 1.1 Will Not Install
2739 Views, 20 Replies
09-12-2012 08:19 AM
Since my AutoCAD crashes when exiting 95% of the time I thought I would install service pack 1.1.  I have the 64 bit version of Autodesk Product Design Suite Premium 2013 which includes AutoCAD, AutoCAD Mechanical and AutoCAD Electrical.  It is a Windows 7 HP XW series workstation.
Everytime I try to install the service pack it does not install, and a dialog box pops up stating "The service pack could not be installed because the expected Autodesk product could not be located on your computer."  To be certain I tried both the 64 bit and 32 bit service pack.  What may be causing this?  Is this possibly caused by the fact that in Autodesk Product Design Suite Premium, AutoCAD is kind of a burried inside AutoCAD Mechanical, somewhat like a sub-program of AutoCAD Mechanical.
Thank you
DarrenP
Message 2 of 21 (2,733 Views)
Re: Service Pack 1.1 Will Not Install
09-12-2012 08:42 AM in reply to: m.granata
yes that would be the reason why its not working
**Master
dmfrazier
Message 3 of 21 (2,717 Views)
09-12-2012 10:14 AM in reply to: m.granata
It appears there has not been a service pack released yet specifically for the 2013 Mechanical product.
http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9240898
sandhup
Message 4 of 21 (2,532 Views)
11-22-2012 02:54 AM in reply to: m.granata
I'm having the same problem, I use autocad 2013 (not mechanical) and it crashes a lot switching from Inventor to AutoCAD. I cannot install service pack 1.1. I have service pack 1 only. :smileysad:
Alfred.NESWADBA
Message 5 of 21 (2,529 Views)
11-22-2012 03:30 AM in reply to: sandhup
Why not? Any message you get? If so then please let us know the message (screenshot), makes it easier to guess then :smileywink:
- alfred -
Alfred NESWADBA
sandhup
Message 6 of 21 (2,527 Views)
11-22-2012 03:53 AM in reply to: m.granata
Alfred. I get the same message as the first poster.
Installation Error
Make sure that you are using the correct service pack for the product.
OK
using Product Design suite Ultimate 2013.
Alfred.NESWADBA
Message 7 of 21 (2,524 Views)
11-22-2012 04:19 AM in reply to: sandhup
if you have plane AutoCAD 2013 and no suite, then a chance is that you have downloaded the wrong servicepack, so verify wehter you have a 32bit or 64bit environement and you downloaded the correspondig sp.
Another option, when your AutoCAD-installation is defect, is to start a repair-installation and then start the servicepack installation
Good luck, - alfred -
Alfred NESWADBA
Valued Mentor
rjay75
Message 8 of 21 (2,085 Views)
04-23-2013 06:50 AM in reply to: m.granata
Did you ever get the service pack to install. I haven't been able to do so yet. I've downloaded the what appears to be the correct version but it still will not recognize Autocad on the machine. I'm using Product Design Suite 2013.
DarrenP
Message 9 of 21 (2,080 Views)
04-23-2013 06:53 AM in reply to: rjay75
are you running a separate autocad or are you running it from electrical or mechanical?
if its from the electrical or mechanical the autocad service pack won't work you have to install the service pack for electical or mechanical
mleslie00
Message 10 of 21 (1,838 Views)
06-27-2013 12:34 PM in reply to: m.granata
I am having same problem installing service pack 2: AutoCAD_2013_SP2_64bit.exe
I have AutoCAD 2013 from Product Design Suite 2013 on a 64 bit Windows 7 computer, but am getting the
"The service pack could not be installed because the expected Autodesk product could not be located on your computer.  Make sure you are using the correct service pack for the product."
Is this a bug in the Service Pack installer?  I see no better choice for a service pack file to install.
