im trying to send a dwg file with pictures which but the pictures dont show up. i created a zip file using the etransmit option and the pictures show up in the file but you can not see the actual picture on the dwg file, only its path. is there a way i can send the file that the picture shows up on the dwg?
thank you
Solved by pendean. Go to Solution.
Hello
Strange !
Because if ALL XREF DWGs and Images used by the main DWG are in the same folder as the Main DWG,
normally all XREFS and Images must be loaded without any problem ...
Have you ALL files in the same folder ?
Bye, Pat
Patrice BRAUD
I did extract it and its all saved in one file. i attached an example below which there were 3 pictures in the dwg and you see 2 in the zip file but they dont show up on the dwg.
Hi, what could be the reason why the third pic didnt attach? I have this problem every time i try to create a etransmit some of the pictures go missing
I think that it is because the third image is inside folder which has Hebrew symbols in it's name - it appears AutoCAD can not handle correctly such file paths, so in spite the folder itself is inside archive, there is no image file in folder with name:
פ ר ק ט ע ץ מ ס ד ר ת Comort - פ ר ק ט ש ט י ח י ש י ר_files
Maxim
i want to create garden designs with pictures and send them in DWG can some one explain as simply as possible how to do this?...please
