Hi guys!
I'm struggling with a file I'm working on because I got to send the file in dwg but it has an X-REF in it. The thing is that I heard you can send the dwg file WIHTOUT sending the xref , either in binder or as another file completely. Apparently the XREF turns into an isolated block that works as any other block inserted within the file.
Is there any way to do that or similar to it? Or I must send the XREF I'm using?
Thanks a lot
Sophia
Solved by 3wood. Go to Solution.
What I do in that scenario is save-as (just a copy for export only) and bind the xref to the dwg you want to send. This maintains your original dwg with the xref. You can right click on the xref you want to include in the dwg you want to send in the manager and bind it to the dwg from there.
Hope this helps. Good luck!
Neal
why can't you send both files?
if that's a real limitation, then you are stuck with the Binding option where you bind the xref and it then turns into a block.
Use ETRANSMIT and teach your client how to use xref.
This is the best way to communicatem, avoid any missing file problem in the future.
I'd say the Etransmit tool should work for you. It will send all the xref files with the main file that they are xreffed into. To make it easier on the person that is receiving the file, make sure the main file has the paths all set to relative for the xrefs. That way when they extract the zip file of its contents, the main file and its xref files will be contained in the same folder and the relative paths will still work.
If you're wanting to send the file without all of the xrefs, then I agree with the other guys that binding would be the way to go.
