The answer to this post is not the pickfirst variable. I select text, a line, anything really then right click, copy and nothing it loses the selection set and waits for me to now select something. I know it sounds like pickfirst, but pickfirst is set to 1. Has anyone else encountered this? 2013 Autocad vanilla.All service packs and updates.
Solved by Patchy. Go to Solution.
That was it. I forgot all about that "undocumented variable". I must have run an old lisp that changed that. Thanks so much!
I'm having a similar problem.
1. Select object
2. Right click
3. Menu appears
4. System automatically "cancels" selection
5. System request selct object.
Any Ideas? I changed all the variable listed on this thread. No help.
The following is the command line history.
Command: PICKadd
Enter new value for PICKADD <1>:
Command: PICKFIRst
Enter new value for PICKFIRST <1>:
Command:
Command: WallStyleEdit
Select walls: 1 found
Select walls:
The command "WallStyleEdit" was selected off the right click menu.
Normally it retains the selction and sarts the dialog box. This is something brand new. Never saw anything like this.
As it is an AutoCAD Architecture issue, probably will be easier to get help at the AutoCAD Architecture Forum.
Henrique
