I have a very old drawing that has been updated several times. It started way back before Annotative text/mtext was available and has been updated to include some annotative text/mtext. It contains scales of 50 and 200. I am now updating again with yet another new scale of 100. All I need are the text/mtext entities that have the 200 scale. All other text/mtext entities can be removed for this update. Is there a way I can select only the entities that contain the 200 Annotative scale?
Thanks.
pendean,
I appreciate your quick reply. But I am a little lost in your response.
First, I said nothing about modelspace. And in general the space your in wouldn't have much to do with selection sets, and that is what I was attempting to do. Select entities based on a property, the property being the annotative scale.
Second, I now realize I am in the Autocad forum and not the Civil 3D forum. My apologies. However, dealing with Annotative objects should have no difference in what vertical version (if any) one is using. I cannot imagine that Autocad "vanilla" doesn't support multiple Annotative scales. To verify try this. Select any text, go to properties pallet and look for the Annotative property. If it set to no, change it to yes. If it says yes, then directly below that is the Annotative scale. Select that and then click the ellipse button to the right. This will list all the scales applied to the entity. If there is only one, click add. Then select another scale and add it. Now you will have more than one scale assigned to that entity. And the space your in still doesn't matter.
None-the-less, we managed to figure out a way to do just what was needed. Here's how ...
Got to a viewport. In my case the viewport was the 100 scale. Turn on the annovisibility for all scales (ANNOALLVISIBLE). This allowed the non-annotative text and the 200 scale text to show but not the 50 scale. Then box in all entities for selection. Next go to QSELECT and change MULTIPLE to TEXT and select ANNOTATIVE and YES. This will filter the selection to the 200 annotative scaled entities. Now go to properties and set the annotative property to NO. That strips all annotative scales from the entities. Now change the annotative property back to YES. That adds back only the current scale, in my case only the 100 scale. Repeat these steps for the mtext entities. Now go back and reset the annovisibility (ANNOALLVISIBLE).
And that's it, only the 100 scale is attached to what was 200 scale entities. All other entities still exist in the drawing, in case I need them later, but they don't show in my viewport.
Dean has been off his game for a while now. That seems to be a theme around here; only read part of the question/issue, then respond in a way that isn't really on topic while interjecting personal opinion instead of just answering the question. Oh, then there are the argument threads... It's like a geeky ACAD D waving match. This place has too many experts for its own good.
