I just installed Building Design Suite Premium 2014 on my computer. Since then, my Autocad 2011 has been acting terrible. Always crashing, etc. So, I will just start using Autocad 2014. However, I cannot find a decent scripting tool for 2014 - 64 bit.
In 2011 - 64 bit I was using Cadig's AutoScript. However it doesnt seem to work in 2014. Whenever I try and load the .arx file, it errors out and tells me that it's not compatible. I see Autodesk Labs withdrew their support for Script Pro back in 2012 (that sucks). So, what is everyone using as a utility to run scripts in Autocad 2014 - 64 bit. A large part of what I do needs to be scripted as I work in series of 100's of drawings and some changes can be much faster running a script.
My computer is running Win 7 - 64 bit and I'm running the 64 bit version of Autocad 2014.
thanks.
Solved by olivier.eckmann. Go to Solution.
Solved by pendean. Go to Solution.
I use Autoscript version 3.2 with my MAP 3D 2014 without any problem.
Olivier
