I am writing a script to rotate a globe (sphere created with mesh). I cannot make it to appear smooth rotation on the screen. Can somebody help me with this?
Thank you in advance.
Solved by hmsilva. Go to Solution.
After setting a UCS at one end of the shaft I wrote the following simple script
ROTATE
GR GLOBE
0.00,0.00,0.00
0.0001
RSCRIPT
Sphere (Globe) rotates, but rotation doesn't appear smooth on the screen and after about 10 seconds AutoCAD shuts down.
ROTATE
GR GLOBE
0.00,0.00,0.00
0.0001
RSCRIPT
I also would use pedean's solution for a presentation.
But if you need to use a .scr for your presentation, you should take a look the DELAY command, and possibly increase the rotation angle... Perhaps something like this
ROTATE
GR GLOBE
0.00,0.00,0.00
1
DELAY 25
RSCRIPT
Hope that helps
Henrique
