AutoCAD Forum
Script to rotate a sphere
5 REPLIES 5
Ivan.Yanev
613 Views, 5 Replies
I am writing a script to rotate a globe (sphere created with mesh). I cannot make it to appear smooth rotation on the screen. Can somebody help me with this?
Thank you in advance.
5 REPLIES 5
pendean
in reply to: Ivan.Yanev
Smooth rotation?
Post your lisp too please so we can see what you used to do it.
Ivan.Yanev
in reply to: pendean
After setting a UCS at one end of the shaft I wrote the following simple script
ROTATE
GR GLOBE
0.00,0.00,0.00
0.0001
RSCRIPT
Sphere (Globe) rotates, but rotation doesn't appear smooth on the screen and after about 10 seconds AutoCAD shuts down.
p_mcknight
I have to ask; Rotate a sphere? In what direction?
pendean
Is this for a presentation or to show someone your final 'sphere' product? Put a CAMERA on a rotating path and record the output would be how I'd do it.
hmsilva
ROTATE
GR GLOBE
0.00,0.00,0.00
0.0001
RSCRIPT
I also would use pedean's solution for a presentation.
But if you need to use a .scr for your presentation, you should take a look the DELAY command, and possibly increase the rotation angle... Perhaps something like this
ROTATE
GR GLOBE
0.00,0.00,0.00
1
DELAY 25
RSCRIPT
Hope that helps
Henrique
”Boost
