Hello:
I have been tasked with trying to create some type of template (or multiple templates, if needed) to convert my coordinates (some having straight lines and some having arcs) into a script file. I will be gathering the coordinates from an excel file then linking them to my script file.
My problem is, I have hundreds of sets of coordinates (all with varying arcs and straight lines and varying order in which arcs and lines are used) in which I'm trying to establish a method to convert to a script file. Also, the total number of lines (arcs and straight) vary. Some have as little as 10 lines and some contain as many as 20 lines total.
I have succesfully created a script file using one set of coordinates but can't imagine doing this hundreds of times over.
I have attached a PDF file showing an example of the coordinates along with the radii (in some cases there is no radius, therefore must be a straight line) and just need some ideas of how I can accomplish this without creating a script file for each and every set of coordinates I have. The example I have is only a small portion of what I am working with.
Any ideas or suggestions of how I can accomplish this would be greatly appreciated. Thanks in advance for your help!
Sincerely,
Ryan
Create text string in Excel similar to this. (this creates text from column A at specific XY locations)
Copy column into new worksheet PASTE SPECIAL - Values
Saveas .txt file
Open in notepad find/replace quotation marks with nothing (remove " ")
save file and rename .scr
drag into AutoCAD
Hope this helps.
JK
How would I apply a radius to the coordinates when needed? And does this just plot the coordinates or actually draw the line as well?
Thanks, very insightful so far!
Works with any command, just as if you were typing at the commandline.
remember spaces are enter.
JK
So do I need to enter the command (pline, line) at the beginning of the script file?
I'm very new at this and don't quite understand where some of the values "-mtext, 15, 0, 1" came from.
Any chance you would be willing to use the coordinates I supplied and show me how my coordinates and radii should be entered into Excel, then transposed to the SCR file to actually make this draw my blade in AutoCAD?
I know this is asking a lot, but if I can get one example, I am confident I could complete the rest. Thank you for your patience with my lack of understanding.
Ryan
Look at attachments. I have included my SCR file, an excel coordinate and a PDF file of what it should look like. I apologize but I am thoroughly confused at this point of how I can get the information from excel to a scr file to draw the object shown.
Any thoughts?????
I don't think it can be possible. I drew lines using the coordinates and how can you have arc that would fit using the given radius.
(See the drawing where the red line is)
