I'm trying to scale down 3D drawings but when I use the 3DSCALE command the perspective gets distorted. Is there a way I can scale my drawing without messing up the perspective?
Can you post an example? I have tried different axis and planes to scale and I am not having the same problem when using 3DSCALE command.
Can you explain why you are attempting to scale a chair?
A chair is what it is. It should be 1:1.
Sounds like you need to change you camera position (zoom) not scale of the part?
I basically need thumbnails of multiple drawings and I want them all to the exact same scale but much smaller than the original drawings. As I said I have little to no experience with AutoCad, so how would I go about changing the camera position? I need to keep the drawing at the custom rotation it is set at.
