AutoCAD Forum
Scale vertically only
5 REPLIES 5
1Sticky1
21352 Views, 5 Replies
Is there a way in cad 13 to scale vertically only?
5 REPLIES 5
Patchy
in reply to: 1Sticky1
No, make it a block then scale different x and y
1Sticky1
in reply to: Patchy
still fumbling around this program....  Make a block?  r u talking about grouping?
Patchy
BLOCK command and make a block out of it/them, give it a name
INSERT that block name and follow the prompt for X and Y scale.
Group is not a block.
vladimir_michl
The easiest way is to copy the 3D objects to clipbpard (Ctrl+C) a paste them back as a block (_PASTEBLOCK). Then change the Z-scale property of the pasted block using the Properties palette (Ctrl+1) - see the sphere+cube scaled in Z:
Vladimir Michl, www.cadstudio.cz  www.cadforum.cz
Do that all the time to fake items on a 45 degree angle.
X = .707
”Boost
