AutoCAD Forum
Saving in Autocad 2014 with Windows 7 OS - Not responding issue
1 REPLY 1
271 Views, 1 Reply
File saving in acad 2014 with win 7 os, freezing the system with not responding on the top.
Commands are written in LISP files (version 2000) and VB6.
Through LISP commands acad 2014 is running and in some sheets it is getting stopped and freezed displaying not responding taking more time more than 15 min for executing one sheet to next sheet.
Kindly help in the above issue.
1 REPLY 1
pendean
So the porgram doesn't freeze if you don't use your lisps and vb6 code? if so, you need to share the contents of the lisps and vb6 code for review.
Otherwise "not responding" is s system level message that basically says in an obscure way "quit tapping your mouse/keybaord until the program finishes whatever you tasked it to do" 🙂
”Boost
