Hi, I'm using LT2014 and recently my saveas dialog box has quit appearing. It was working when I was using a docking station and multiple monitors. Previously learning my lesson that undocking would screw up my dialog boxes if I shared screens, I had moved each of the dialog boxes to the primary screen and tested each to ensure all were compatible. I thought all would be fine but powering up the file I find saveas being the only dialog box (so far) that seems to have disappeared. I have since connected to another monitor, extended display doesn't find the missing dialog box, nor does filedia<1> (it already was set to <1> and I've tested setting to <0> and then setting back to <1>. Thanks in advance for hte help.
If the dialog box is off the screen press ALT+SHIFT+M then press an arrow key. Now move the mouse and the box will be attached to it.
Reset worked!! It also took care of some other annoyances and only took a couple of minutes before I was back at work.
Thanks for the speedy reply.
