Hello, I am wondering if anyone can help me make multiple copies while rotating. I am running AutoCAD 2014 on my Mac. I am attempting to make multiple copies while maintaing the same base point. When I attempt to do so I can only make one at time. For example: I make a simple line. I then select the grip in the center of the line then right click and select ROTATE, then select a base point, then right click again and select COPY. I then hold down control and attempt to make more than one copy. I then left click and it rotates one copy, but then the command is over. I can't make another rotated copy without starting all over and selecting the base point again. It only allows me one copy and rotate at a time. It is very frustrating! I have attempted to use the command key, shift, command+control, command+shift, almost every combination possible. I have searched the internet looking for ways to do so and the only thing I have found simply states that all you have to do is hold down the control key and you can make as many copies as you'd like. It seems like a very simple command, but for some reason it does't work. Any help would be greatly appreciated.
