AutoCAD 2013/2014/2015
*Expert Elite*
Patchy
Message 11 of 19 (523 Views)
Re: Right Click Menu Shortcut keys
01-30-2013 01:55 PM in reply to: Pollmuller
Autodesk changes the right click menus all the time, it's not the drawing, it's in your CUI.
I want to see that block because it's AECpoint, that way I can find the command relates to it..
Active Contributor
Pollmuller
Message 12 of 19 (520 Views)
01-30-2013 02:15 PM in reply to: Patchy
I just saved my 2013 drawing as 2010, let me know if this does or doens't work for you.
AUTOCAD Civil 3D 2013
Windows 7
Processor: Intel (R) Xeon (R) CPU W3565 @ 3.20GHz
Installed Memory (RAM): 12.0GB
System Type: 64-bit
Erika
*Expert Elite*
Patchy
Message 13 of 19 (508 Views)
01-31-2013 06:15 AM in reply to: Patchy
I opened your attached drawing with 2013 C3D but that point block wasn't there.
Active Contributor
Pollmuller
Message 14 of 19 (505 Views)
01-31-2013 06:44 AM in reply to: Patchy
I'm not sure what you mean by point block. The points are in a point group...
Windows 7
System Type: 64-bit
Erika
*Expert Elite*
Patchy
Message 15 of 19 (503 Views)
01-31-2013 06:48 AM in reply to: Patchy
Point block is a block brought in when it matches point description in field book or data file, point group is a group of identical points. That is how it defined back in land desk top.
Ask the civil 3D group, they know how to add that option to right click menu.
Active Contributor
Pollmuller
Message 16 of 19 (494 Views)
01-31-2013 07:45 AM in reply to: Patchy
Oh ok cool. I'm going to have to look into that more because that would be super helpful for me!! CAD will take the points that you import and based on their descriptions sort them into different blocks? Very niffty!
But back to this issue, I just want to be able to flip the label from the left to the right. I always have 2 points in the same place and it used to be just a quick click to swap the label to the other side. I know I can make a label style on the opposite side but this way was much faster.
Just a selection from the right click menu...
Windows 7
System Type: 64-bit
Erika
*Expert Elite*
Patchy
Message 17 of 19 (489 Views)
01-31-2013 08:00 AM in reply to: Pollmuller
If you can attach another drawing that created with C3D 2012 and has that block, I will find out what that comand is.
(Once it opened with 2013 and saved back to earlier version, all get messed up and difficult for me to find out)
Active Contributor
Pollmuller
Message 18 of 19 (485 Views)
01-31-2013 08:07 AM in reply to: Patchy
I don't know how to do that... sorry.
I only ever worked with point groups.
Windows 7
System Type: 64-bit
Erika
Active Contributor
Pollmuller
Message 19 of 19 (463 Views)
02-05-2013 01:22 PM in reply to: Patchy
Thank you for all your help!!
This issue has been resolved and I'll be damned if I can tell you how I did it.
Windows 7
System Type: 64-bit
Erika
Need installation help?
