AutoCAD Forum
Resizing the display or view of the Xref & Layer Dialog Boxes
10 REPLIES 10
Message 1 of 11
Drafter1981
5163 Views, 10 Replies
To All,
Just ran into a situation with trying to "Resize the display or view of the Xref & Layer Dialog Boxes"
I'm now using AutoCAD 2015 and have migrated most of my setting so, for the most part I havent had to change much.
What I have noticed is the "Dialog boxes" do not have the same look, size as in AutoCAD2014....
I'm have not seen anything yet in the option settings on how to reset, or override the box settings.
It would be great to actually "see" the full path names without constantly scrolling over files.
As usual any help would be aprecieated.
Milt Fitzgerald (a.k.a. Drafter1981)
Fitz’ Digital Cad Service L.L.C. (Consulting Business)
https://sites.google.com/site/fitzdigitalcadservice/
10 REPLIES 10
Message 2 of 11
rkmcswain
in reply to: Drafter1981
The layer palette is just docked. Undock it and stretch it out to whatever you like.
Same basic premise for the xref palette.
You could also use the CLASSICLAYER and CLASSICXREF commands.
Set LAYERDLGMODE to 0 to force the LAYER command to use the CLASSICLAYER dialog box.
R.K. McSwain     | CADpanacea | on twitter
Message 3 of 11
nrz13
in reply to: rkmcswain
Additionally, if you're unable to drag/resize the palettes, look into the LOCKUI system variable:
0  Toolbars and windows not locked
1  Docked toolbars locked
2  Docked or anchored windows locked
4  Floating toolbars locked
8  Floating windows locked
Work:  AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 32GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
Message 4 of 11
Milt-Fitz
rkmcswain
Just responding to the post & your information from my office location....
I have found the "PROBLEM"...
Looks as if Autodesk decided to remove the option to resize your Tool Pallets or Dialog Boxes, (refer to attachment or link).
How to Lock or Unlock the UI in AutoCAD 2015
I'm not sure what rocket scientist thought that was a good idea... Smiley Frustrated
That being said "How do we fix the problem?"
Again, any suggestion would be appreciated.
Siemens Industries (Full-Time Office Position)
Message 5 of 11
nrz13
in reply to: Milt-Fitz
Enter LOCKUI at the command line and see my previous post for the options to unlock and lock.
Message 6 of 11
rkmcswain
No they did not remove the option, they only removed the GUI way of accessing it.
You can still type in LOCKUI as @nrz13 indicated. I originally did not mention this because you (or someone) would have had to lock these elements down - because being in a locked state is not the default.
Message 7 of 11
Milt-Fitz
Thanks for you help...
This seems to work for what I need it to do for now.
As you may have seen, or noticed, I'm an old dog and prefer to "Type" in the commands.
That being said, why would Autodesk go from a GUI for something like this in lieu of typing in the command?
Just saying. Anyway, thanks again and I'll also mark this as a "Solution"
Message 8 of 11
rkmcswain
The big picture global answer? I like to refer to a quote from @sboon
"The basic premise which you must keep in mind is that the interests of the shareholders supersede everything else."
- @sboon
To break that down further, they redesigned the GUI for 2015 pretty heavily. The status bar was severely changed and for whatever reason I guess they figured not many people used the LOCKUI icon so that removed it.  I really have no clue other than to say selling new licenses is very important, and keeping the "look" fresh is important to that. I'll just leave it at that.....
Message 9 of 11
sboon
I should probably put this quote on a T-shirt and sell them at Autodesk University....
Smiley Very Happy
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
Message 10 of 11
rkmcswain
in reply to: sboon
I'd buy #1.
We'd probably all get kicked out and banned 🙂
Just kidding @autodesk !
Smiley Happy
Message 11 of 11
Drafter1981
rkmcswain & nrz13
Not sure why the solution box was pointed to my request for help... You two actually gave me the solution to fix my issue.
Anyway, I unmarked myself and listed your tips to solve this problem.
Hopfully this will get added back into a future version of AutoCAD.
Thanks again,
Milt Fitz
”Boost
