What's the fastest and easiest way to resize multiple rows and columns to match others without dragging grips. See attached.
Example, I want to make rows 10,11,12 the same height as the others and make all the columns the same width as column A.
Solved by LyleHardin. Go to Solution.
TABLEDIT,
TABLESTYLE will allow you to modify the tabel in same dialog as when you create a table.
Thanks for the response. I am aware of creating a table style to control the spacing. How do I adjust the row height so they are all the same after I have manually grip edited them?
Thanks.
grab the bottom grip, amd drag it up as high as it will go. row height will resize to the minimum needed to fit the content & margins
Yup. Got that. But is there a way like in Excel to set multiple row heights or column widths in one shot. Probably not.
You can pick and drag from INSIDE the upper left cell to INSIDE the lowest right cell to select the entire table of cells.
Now, in your Properties Manager, you should be able to set the height and width of those cells.
You can also do this by selecting Rows or Columns.
I select the tables but I only have Table Properties? I can not find anywhere to adjust the height of the rows within it? Please help.
You need to select the cells, not the table, for the properties of cell height to show up.
Pick and drag INSIDE the cells to select a row or rows.
---edit---
But, after looking at your image again, I notice it's a Civil 3D piping table. That is a different animal than a regular AutoCAD Table, I think.
You should probably post that question in the Civil 3D forums. It may work the same, but it may have to do with the Civil 3D table styles.
How to make columns with alternate width size ?
