AutoCAD Forum
repeating FILLET command when using keyboard
10 REPLIES 10
Message 1 of 11
1594 Views, 10 Replies
I want to make it so that whenever I type F for FILLET the MULTIPLE option is selected so I don't have to type F then M.  Is there a way to make it so that when I type F it always gives me the multiple option without my having to type F then M?  How would I do that?
10 REPLIES 10
Message 2 of 11
Patchy
Use autolisp, this group can get you the answer.
http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/bd-p/130
Message 3 of 11
dbroad
Short answer:
Add this to your acaddoc.lsp:
(defun c:fm()(command "_.fillet" "u")(princ))
If you don't have an acaddoc.lsp, you will need to create one with notepad and put it in a folder that is marked with the trustedpaths in your support files of the profile.
Architect, Registered NC, VA, SC, & GA.
Message 4 of 11
in reply to: dbroad
I found the acaddoc.lsp file but am hesitant to alter it because I don't know what I'm doing!
Would I just copy and paste (defun c:fm()(command "_.fillet" "u")(princ)) at the bottom of the file?
Message 5 of 11
Patchy
Found acaddoc.lsp but it has to be the right one to paste to.
At the command line, type in (findfile "acaddoc.lsp")
It will return the right acaddoc.lsp to paste to.
Message 6 of 11
dbroad
Yes, just paste it in.  And in AutoCAD be sure to test to see that you have the correct acaddoc.lsp per Patchy.
There are other ways to include this lisp but using acaddoc.lsp is probably the simplest method.
You can also read about the startup suite.
Message 7 of 11
pendean
Start MULTIPLE command.
Now start FILLET command.
Enjoy.
You can use MULTIPLE command with any other command in AutoCAD.
Message 8 of 11
edwin.prakoso
in reply to: pendean
That is cool Dean, I never knew that command before.
If this post solves your problem, please mark it as solved. It will help others with a similar problem to find a solution.
Kind regards,
Edwin Prakoso
LinkedIn | Website | Twitter
Message 9 of 11
in reply to: Patchy
did not work; it returned NIL. I'm using AutoCAD 2014.
Message 10 of 11
rkmcswain
Some of the same answers you received over here the day before.
R.K. McSwain     | CADpanacea | on twitter
Message 11 of 11
Patchy
Make a text file then rename it acaddoc.lsp
Put in the code
Then do the same (findfile "support")
Move the acaddoc.lsp into that support folder
Restart autocad.
”Boost
