AutoCAD 2013/2014/2015
0 Kudos
Post 1 of 5
Registry key to detect Autodesk Suite products
657 Views, 4 Replies
02-13-2013 01:20 AM
I installed 3 suites on my workstation :
- Product Design Suite ultimate 2013
- Factory Design Suite ultimate 2013
- Building Design Suite ultimate 2013
In the registry key, I only find "Product design Suite" installed with  "ProductEdition" Key.
I did not find a trace of the other suites install.
1) Do you know how to trace the other suites in the registry ?
2) How to know in the registry if AutoCAD 2013 belongs to one of these 3 suites (cause the serial number = 000-00000000 in the registry) ?
651 Kudos
Post 2 of 5
Re: Registry key to detect Autodesk Suite products
02-13-2013 05:59 AM in reply to: jrchh1
you can open up the product and get the serial number
0 Kudos
Post 3 of 5
02-13-2013 06:56 AM in reply to: DarrenP
My goal is to find the information recorded in the register.
Open the product and go and check the serial number, I can do it also via _pkser.
My real question is :
How do I know which product belongs to what Suite in the registry key ?
For your answer, when I launch AutoCAD 2013, I can see that Building Design Suite appears.
In about of AutoCAD, I always see Building Design Suite and when I look at it's serial number, il belongs Factory Design Suite.
See attached file.
651 Kudos
Post 4 of 5
02-13-2013 06:57 AM in reply to: jrchh1
are these network licenses?
894 Kudos
Post 5 of 5
02-18-2013 07:36 AM in reply to: DarrenP
Darren makes a good point.  If they are network seats, then it is irrelevant.  The license manager will properly handle the licensing of the product and cascade the product to the best available license.
