The Regapp ID Cleanup Utility for AutoCAD 2013/2014 is not working for me. It is installed correctly. The 2010 and 2015 versions work on my machine but the 2013/2014 version crashes every time. Anyone else have issues?
I installed files with all Autodesk programs closed. No difference. Same thing with the scales cleanup utility. 2010 and 2015 versions work. 2013/2014 version does not.
Let me add that it is not working on multiple machines. We are using Civil 3D...I don't know if that has something to do with it. Each machine is configured different, with different combinations of version installs. I don't know if there is a common denominator yet.
I originally installed it in: C:\Program Files\Autodesk\Autodesk AutoCAD Civil 3D 2014\ ...didn't work
Now installed in C:\Program Files\Autodesk\AutoCAD 2014\ ...working
Thanks for the replies.
Great find Brysull! We've been having the same issue & changing the folder worked like a charm! 🙂 Thanks for sharing!
