I have been using Reference Manger to fix the Xref path of one Xref to multiple drawings with success.
However, if I rename the Xref then I’m out of luck. Is there a way to use Reference Manager to rename and repath the xref?
I don't think there is a way to change the reference name as it works a lot like if you were to repath the reference in the drawing itself.
Try with the free BatchInDatabase tool to repath to renamed xref files without opening the drawings which is avaiable to download from Autodesk Exchange App store
Below is from the help file
Xref - Redirect:
Redirect references, xref, Image, PDF underlay and DWF underlay will be redirected to new location. Use this command to redirect all references to new location:
Enter * in old path which means all selected reference type will be redirected to new location
Alternatively use this command to find and replace a part of path with new path values
Each reference file which is going to be changed will be checked for the existence in the new location; if the reference file does not exist in the destination location then the path of that file will not be updated
If there are two or more same file names exist in current and sub-folders, the first one from the current folder will be taken
Usage:
Example-1
You have an image "Test.jpg" which has been referenced in multiple files
You create another image with same name but different image type, let us say "Test.png"
Since we are changing only the extension , the path will remain same, so both images should be in the same folder, the command checks the file first for its location, if found then replace the name, thus the reference is changed to new image type.
Example-2
You have an image "P:\ABC-123\DD\Iamges\Test.jpg" which has been referenced in multiple files
You have another image which is located in different directory "P:\ABC-123\WD\Images\Test.jpg"
Here we have a part of image path is different, the command parameter will be as below
Example-3
You have another image which is located in different directory "P:\ABC-123\WD\Images\NEW.png"
Here we have a different path, file name and image type, the command parameter will be as below
Hope this will help
app mentioned above does not appear to exist anymore (year 2020)
anyone else have a solution for batch renaming xref's? Reference manager is great if the file names don't change, unfortunately, I often move files from job to job changing not only folder path, but also file naming convention.
