Hi all,
When I use the refedit command on an xref
Command: _refedit
Select reference: 3606.255802,-82.406967,0.000000
*Cancel*
1. Tried unattaching and reattaching
2. Tried resaving it under a different name
3. Tried restarting autocad
4. Tried restarting computer
Nothing has worked, refedit simply cancels. Any help would be greatly appreciated.
Welcome to the Autodesk Community, arthurjwong
Perhaps there may be some objects created by a third-party application, try to set DEMANDLOAD System Variable, to 3 and try again the REFEDIT command.
If the behavior still the same, consider using the XOPEN Command...
HTH
Henrique
