AutoCAD 2013/2014/2015
Valued Contributor hlo
Valued Contributor
hlo
Message 1 of 3 (119 Views)
Recovery a AutoCAD207 file
119 Views, 2 Replies
01-22-2013 02:20 AM
HI
Can anyone explain the behavior for this file.
The file are created in AutoCAD 2007.
It is a drawing with 2D and 3D drawing in it.
When I open this file in my AutoCAD2013 and make the recovery as AutoCAD suggest
The are no 3D left in the drawing. The file are working fine and whiteout no plebes I AutoCAD2007
System:
Autodesk Product Design Suite Ultimate 2013
AutoCAD Mechanical 2013
Regards
Henrik
*Expert Elite*
Alfred.NESWADBA
Message 2 of 3 (110 Views)
Re: Recovery a AutoCAD207 file
01-22-2013 04:38 AM in reply to: hlo
at least there are some AEC-objects in it as (I tested it with AutoCAD 2012 now) the AEC-modules are loaded.
And when doing the _RECOVER it tells me that there are 5 objects deleted (I don't know which ones, of course). So the question I have: are you really sure that there are 3D-objects in it? I see 3D-like objects (flattened ones), but nothing in it is 3D.
I would suggest then: open your drawings with 2007, run command _WBLOCK and create a new drawing from your selected objects in modelspace. Then open this new drawing in 2013 (and import your layouts if there are one and you need them in a second step).
Good luck, - alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
Valued Contributor
hlo
Message 3 of 3 (89 Views)
01-22-2013 11:18 PM in reply to: Alfred.NESWADBA
HI, I tried this WBlock, but it didn’t work out too.
Regards
Henrik
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
