Hello!
Is anyone having the same issue as me ?
On Autocad exit, it prompts me if I want to save the drawing I am in. I then click Yes. When I re-open this same file later on, it always asks me to recover it.
If I save via the save command, and exit after, then it does not need to recover the drawing....
This starts to get annoying when using Sheetsets, because it does not plot the entire job correcty.
Thanks for your help on this !
Guillaume
Autocad 2015 Full,PC, Windows 7 SP1.
Solved by info. Go to Solution.
Did you change the Autosave path to a location that doesn't permit Autocad to automatically delete them when closing normally?
When the Recovery manager opens, which drawing file has the most recent date.... the .sv$ file, the .dwg file or the .bak file?
Neslty2,
When I open the file, make some modifs in the drawing and close the file - the save prompt opens up. I save. The file closes.
In the file folder, the .dwg is saved with current time and date.
The .bak is not updated.
In the "temp" folder, where the autosaves are saved, these files appear - see image.
I have the Civil 3D plugin installed - to convert and read AEC objects... Would this be part of the issue ? Although the saving error does not appear 100% on each drawing I work on and it does not seem this error came up after I installed this. It has been installed for a while now.
Thank you for your time,
Guillaume
