How can i rearrange Multiple Attributes of blocks in the same Format globally?
I have 100 - 125 Different Annotative blocks in the drawing and each of them has 5Attributes. I don't know how can i re arrange the Attribute display to a certain style globally? The blocks are off the same scale but have different roatation.
Is there any lisp file / command that helps you to rearrange the attributes?
Apologies if this topic has been discussed before but i Can't see the solution here. please help.
Mark,
Thanks for the suggession but Battman is not doing any job for the need i have on this instance.
I have 100-125 different annotative blocks, all have different rotation, each block has 5-6 attributes.i want all 5 attributes to be arranged on top of eachother & at a certain distance from the insertion point. ( i can do that manually but having more than 100 blocks it makes 600 Attributes and i have 2 scales for all those blocks so 1200 Attributes to be rearranged manually. 😞 )
Don't see any command that does it globally and allows you the control to rearrange the attributes in a certain style globally.
regards
Battman should work.
Although after you've arranged the attributes how you want you need to use ATTSYNC to resynch all your blocks.
Howard Walker
