AutoCAD Forum
Reading Civil3d points in AutoCAD
4 REPLIES 4
DaveT4287
334 Views, 4 Replies
Is there a way AutoCAD 2015 can read Civil3D surfaces and survey points?
4 REPLIES 4
If by read, you mean show up correctly as they do in C3D, then yes, look for the correct object enabler. If you mean get useful information like you would from C3D, then no, they are only going to come in as proxy objects even with the enabler.
Yes, We want them to show up for other people that do not have C3D.  Do you happen to know if it would work with LT too??   Thank you.
That I do not know, you will have to download and try, search for "C3D 2015 object enabler"
Thanks Conor.
”Boost
