AutoCAD 2013/2014/2015
Distinguished Contributor
Light_Guy
Message 1 of 3 (172 Views)
READ ONLY pet peeve
172 Views, 2 Replies
01-15-2013 07:17 AM
Can someone PLEASE explain to me, why, when I open a drawing using the READ ONLY option from the user interface window, that I still get prompted to save the drawing when I exit??
Paul Hamor
"Always good ships!"
*Expert Elite*
dgorsman
Message 2 of 3 (139 Views)
Re: READ ONLY pet peeve
01-15-2013 04:07 PM in reply to: Light_Guy
Sometimes drawing settings are changed (e.g. custom ACADDOC.LSP file changing system variables), other times its as simple as changing the viewpoint via pan/zoom operations (yes, that is considered a save - the file is opened with the last view setting, is it not?).  AutoCAD doesn't know why the drawing is read-only - it could be a "template" DWG in a read-only folder which is intended to be saved somewhere else.  The prompt isn't completely useless.
If you are going to fly by the seat of your pants, expect friction burns.
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
Valued Mentor
KLYPHY
Message 3 of 3 (131 Views)
01-16-2013 08:05 AM in reply to: Light_Guy
There are times I want to copy a drawing from a previous project, make a few changes, and then save it into a current project.
To insure that I don't accidentally change the previous project's drawing, it is safest to open that drawing READONLY, then SAVEAS to the current project.
I can safely make changes before or after the SAVEAS.
If I forget to saveas, when I close the drawing, it'll ask me to save or not.
So, I actually like that feature.
Read Ya Later -KLYPH
Announcements
Need installation help?
