AutoCAD Forum
Re: Geo Map
2 REPLIES 2
walkhy
270 Views, 2 Replies
Re: Geo Map
hi forum:
anyone have problem with the GEOMAP, dont start the comand and finded a solution with a hotfix directly at the homepage autodesk, both when i copy the ARX file dont knowed the comand.
please help
2 REPLIES 2
jthornton
in reply to: walkhy
I am having the same issue. I have downloaded all the service packs and installed the hotfix but still cant see the maps from GeoMap command. Any help would be nice. I am running the 2014 Civil 3D AutoCad.
Thanks, Jason
Murph_Map
in reply to: jthornton
Thanks, Jason
If you installed the hotfix following the readme and still have issues you may need to sign out of A360 first then sign in when you connect to the maps.
Murph
Supporting the troops daily.
”Boost
