I would like to hide some of the items along the title bar from view.
How to hide, or better yet, completely remove?
I have uninstalled the 360 yet "Sign In" still remains.
"With your Autodesk® 360 account you can save files to the cloud. View and edit them using any web browser or mobile device."
This statement goes against our company policy regarding the transfer of copyrighted material.
Sure, it is an innovative approach, but not everyone has the privilege to take advantage of this feature.
Therefore this item must be able to be removed from view on a per-case basis.
If I cannot remove, at least point me in the right direction as to how to minimize the search pane so that it remains minimized the next time AutoCAD is fired up.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
Solved by Patchy. Go to Solution.
