AutoCAD Forum
"Menuload" == "CUILOAD" command equivalent icon
7 REPLIES 7
Message 1 of 8
SandraPwint
2044 Views, 7 Replies
Hi
Techical Team whom it may concern,
could you please answer following question;   Using "Menuload" == "CUILOAD" command in AutoCAD command
bar, I can able to open Load/Unload Customizations window for submenu bar.
Can I check and find, is there any specific icon or menu drop-down bar to call this function call "Menuload" ?? without typing in command line.
I very keen to know whether this icon exist and how to call out?
thanks and regards,
Sandra
7 REPLIES 7
Message 2 of 8
rkmcswain
in reply to: SandraPwint
When I search the 2015 acad.cuix, there is a "Cuiload" command entry. I'm not sure if and where it is in the menu, but you could place it where ever you wanted.
R.K. McSwain     | CADpanacea | on twitter
Message 3 of 8
steve216586
You can make a command alias for it and assign it to any key you wish.
"No one can make you feel inferior without your consent. "-Eleanor Roosevelt
Message 4 of 8
pendean
Menuload only calls CUILOAD, it doesn't exist on ti;s own anymore.
Make an icon if you can't find it already in place: start CUI command, find CUILOAD in the commands list, drag it to your preferred Panel, save your workspace and you're good to go.
Now read this to learn how to do all of that: http://www.cad-notes.com/5-autocad-customization-cui-tutorial/
Message 5 of 8
steve216586
in reply to: pendean
Or...
1. You can type in "ALIASEDIT" on the command line.
2. When the dialog pops up click on "ADD"
3. Type in any letter or symbol you want  as an alias then scoll down the list of commands to CUILOAD.
4. Click "YES" to the SAVE current workspace settings.
Then, use that alias anytime you want to call up CUILOAD
Message 6 of 8
pendean
Is everyone not noticing that the OP asked to/doesn't want to type anything?
Message 7 of 8
SandraPwint
in reply to: steve216586
Thanks for your reply. got the answer.
Message 8 of 8
SandraPwint
”Boost
