AutoCAD Forum
"CO" Keyboard Shortcut Defaulting to Color not Copy
1 REPLY 1
529 Views, 1 Reply
I was hoping someone could shed some light on an issue I have been experiencing.
When I type "CO" in Autocad 2015 the command is defaulting to color, instead of copy.
I have even removed the color alias "col" from Alias Editor.
Any suggestions would be much appreciated.
Thank you.
Rich
1 REPLY 1
pendean
Edit your PGP file and see what's going on: if CO is listed as COPY at the bottom of the list (program reads from top to bottom so last entry governs) then you may have an add-on or lisp that hijacked CO (they load aftr the PGP file).
Type this at the command line to ensure you are accessing the correct acad.pgp file:
(startapp "notepad" (findfile "acad.pgp"))
Remember to run REINIT command afterwards to reinitialize the PGP file.
”Boost
