Are there any tools within AutoCAD to purge out entites created in the Civil applications?
I get the 'proxy warning' even when there are no elements displayed in modelspace or paperspace. I want to do more than turn off the proxy notice, I want to actually cleanse my file of these entities.
Solved by Hugh_Compton. Go to Solution.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
Have your tried the ZombieKiller app for AutoCAD? It will allow you to select and delete proxy objects with a simple to use interface.
yep, that ZombieKiller app is awesome. Autodesk should give them $1 million, and include it in autocad. Even allow it to run automatically so I never have to see 'civil' objects again...
thanks.
We got similar comments from clients we supplied drawings to. They couldn't copy and paste, because there Autocad was telling them the drawing had proxy objects. The solution I've came up with is to start a new drawing using the acad.dwt template instead of the template supplied by Carlson (our add-on Civil package).
We copied and pasted the existing drawing into the newly opened drawing (the customer couldn't copy and paste, but we could) and saved as. This seems to work for our customers.
