AutoCAD Forum
pull down menu "Data View" Does not work
4 REPLIES 4
497 Views, 4 Replies
Dear Autodesk
See screenshot
The data view pull down menu commands are not working at all
Can you please fix this
Regards
Don
4 REPLIES 4
Albert_Rius
in reply to: 276040
Hi Don,
The "Data View" menu is not comming with plain AutoCAD 2014. Did you installed any other application?  Seems that the application that should be managed by this menu is not installed or not loaded. Can you reinstall it?
Can you provide more information about this application/customization?
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Albert Rius
Technical Support
Autodesk, Inc.
in reply to: Albert_Rius
Hi Albert
I have plant design suite premium installed
Albert_Rius
in reply to: 276040
Hi Don,
The issue is that all these commands will not work until you have a valid database connection in your drawing, you need to run the DBCONNECT command first to activate all these commands. It will load all  modules needed to be executed.
I hope this helps
Albert Rius
Technical Support
Autodesk, Inc.
Hi Albert,
Thnx for the answer
I totally forgot about dbconnect 🙂
The commands are working fine 🙂
Regards
Don
”Boost
