Dear Autodesk
See screenshot
The data view pull down menu commands are not working at all
Can you please fix this
Regards
Don
Solved by Albert_Rius. Go to Solution.
Hi Don,
The "Data View" menu is not comming with plain AutoCAD 2014. Did you installed any other application? Seems that the application that should be managed by this menu is not installed or not loaded. Can you reinstall it?
Can you provide more information about this application/customization?
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Hi Don,
The issue is that all these commands will not work until you have a valid database connection in your drawing, you need to run the DBCONNECT command first to activate all these commands. It will load all modules needed to be executed.
I hope this helps
Hi Albert,
Thnx for the answer
I totally forgot about dbconnect 🙂
The commands are working fine 🙂
Regards
Don
