can you explain what did you changed step by step ?
Where i have to go and what to change in windows 10 please ?
The folder the user was trying to publish to was on the server. So I had to change the Share permissions on the server, not the client. The server is Windows 2012. I right clicked on the folder and went into Properties. I selected the Sharing tab, and clicked on the Advanced Sharing button. I then clicked on the Permissions button. I selected the security group the user was a member of and checked the Allow box next to Full Control.
Sorry, but this issue is in no way "solved" as the thread indicates. The purported solution is not a solution at all, but rather a workaround, and one that we cannot accept or implement.
We are having the same issue, and I can confirm that what brielindquist said is also the case for us currently with AutoCAD 2017. I really don't see how this can be anything except a bug in AutoCAD.
On our network, end users are never given the "Full Control" permission. They have every permissions except the ability to "change permissions" and to "take ownership". They have no need for these permissions, and we have no interest in granting those permissions to workaround (not fix) this issue. No other program has a problem overwriting files with without these permissions, so the issue is with AutoCAD. The workaround we choose to use is to have users publish to PDF rather than export to PDF.
Autodesk -- There is more than enough information in this thread to easily reproduce the problem, so please fix it.
I agree with @ted_kovacs
This does not resolve the issue. After trying to resolve the same issue (2017) in the way described above, we have come to the conclusion that the issue still persists.
Even if it was working it is nothing more than a workaround.
What is the best way to get this on a to do list?
Well I have encountered the same file is open in another program error in my Access database. I was actually get annoyed with this error because I haven't opened the application anywhere or in any program. When I researched a lot about this issue I got this helpful post and finally I have overcome this issue.
You can also check out the link from which i have got idea to resolve this file is open in another program error.😎
