AutoCAD Forum
Proxy Objects/Graphics Macro
8 REPLIES 8
Message 1 of 9
1289 Views, 8 Replies
Hi
When I am binding a dwg with multiple xrefs obviously proxy objects/graphics will stop the drawing from binding, so I try the following:
- purge and audit
- dxfout, purge and audit in the new dxf and then save back to dwg and purge and audit again
- dgnpurge (from an external .net macro)
The above will work however it can be timely for a set of drawings with multiple xrefs.
Is there a macro to indicate where the proxy objects are (eg what layer, what xref etc)
Is there a macro that can batch remove proxy objects from a drawing set?
I am using AutoCAD 2013.
8 REPLIES 8
Message 2 of 9
ennujozlagam
hi try to read this maybe can help you, thanks.
http://www.cadmanagertools.com/Downloads/help/BIE_help.pdf
Message 3 of 9
in reply to: ennujozlagam
Hi ennujozlagam
Thank you for your reply. I spoke with a colleague and there are number of batch script programs available.
Where this program will fail is when I am creating a new dxf file (ie save as dxf, as part of the clean up process) and going into the dxf and purge and audit, then save as again back into a dwg and purge and audit.
I believe a .net program would need to be created especially as part of the clean up process creating a temporary dxf file, applying commands to thie temp dxf file and then save as dwg and delete the temp dxf file.
Is there .net macro created that could help with this.
Message 4 of 9
hgasty1001
This may help: SuperPurge
Gaston Nunez
Message 5 of 9
pendean
There is a freeware in the AutoCAD Exchange Apps Store that does a decent job of removing proxy objects: ZOMBIEKILLER. Try it. Also has a batch mode I believe. There are also better free PURGE tools too.
Message 6 of 9
in reply to: pendean
Hi pendean
Thanks for the suggestions. I tried Zombiekiller, didn't detect the proxy objects even though the proxy graphics window poped up.
I am trying DWG-PURGE.
If there are any other free programs that other have used let me know. I bet others will also benefit from the suggestions.
Thanks again the suggestions.
Message 7 of 9
greg_battin
What "flavor" of AutoCAD created the proxy objects? (Civil, Map, Plant...)
Another command you might want to try is -EXPORTTOAUTOCAD http://help.autodesk.com/view/ACD/2015/ENU/?guid=GUID-86C80CA1-F237-4AE6-8A43-2E9CA06A03A8
~Greg
Message 8 of 9
in reply to: greg_battin
Hi greg.
Ok I think I'm more on top of this. I installed the AutoCAD 2013 Civil Object Enabler and that seemed to work.
I tried -EXPORTTOAUTOCAD however that didn't help the problem.
So is it a matter of installing the object enabler of the program that is detailed in the Proxy Graphics Window, to remove the proxy objects.
Message 9 of 9
greg_battin
Unfortunately no.
If you can have someone with C3D open the file and then use the command -EXPORTTOAUTOCAD or AECTOACAD, it will convert the proxy objects to ACAD objects. The program that created the proxy objects also has to be the program to convert them to ACAD.
But at least you have identified what program created the objects.
I would do it for you but I am not a C3D guy.
~Greg
”Boost
