Need to check to see if several drawing have proxy then I need to figure out what they are if they are graphic then need to conver them to autocad objects I need to turn the enabler on and off is there a way to do it?
that show the proxies I want to know once you down load a enabler does that always working in th backround and if so can you stop it form working, I'm just asking about any enabler.
Oh I see. I think you're out of luck on that one unless there is an undocumented variable that I am unaware of.
I was hoping no one would say that, so once you have the enalber there is no way of checking to see if it is working or not, that not good one would have to assume that then enabler is working. ????????????????????
I am learning all that, was on AutoCAD 2002 back in 2007 then moved to solid works and now I am back on AutoCAD but it 2013 a lot has change, never had to deal with the proxy stuff before, to many now programs out now a days, just need to figure what is the best way to fine the proxy and then see if i can or have to redraw them, but just finding a proxy is the hardest task,
Don't get me wrong never said they where not there I just did not have to deal with them back then, and I do agree with talking to the higher above, just need all the fact and as much knowledge that I can get before I go ask for something. so thanks for the info
