Using a new layer, I traced over some simple rectangular ductwork objects on an AutoCAD 2014 drawing. Those objects were created with third party software called Practicad that runs on top of AutoCAD. I know they were done with Practicad because I needed their enabler to make the ductwork visible , plus I was not able to snap to the objects. I then copy/pasted the new layer containing the tracings onto a blank AutoCAD 2014 drawing. In doing so, I must have brought in hidden Practicad items. And so what should have been, say, a 100 kilobyte file, turned out to be 20 megabytes. Now if I try to do a simple qsave, it takes a couple seconds on both my well-equipped laptop and desktop machines. And if I try to copy the objects to paste them elsewhere, it becomes a multi-minute operation - or it freezes the program. I've tried the usual audit and purge operations. In fact, purge dialogue box reported very few entities. But the funny thing is my colleague with very similar computers and software experienced zero lag time with this same file. If I save the file as dxf and import it into sketchup, a report says I brought in 4,300 blocks! So my questions are:
1. Why did the proxy stuff come along for the ride during a simple cop/paste of one layer of simple objects from one cad drawing to another?
2. How can I see what the hidden proxy stuff is in the cad program?
3. Why was my colleague able to work the file effortlessly, despite its drawbacks?
4. [Un-related and not super-important] What does the term 'clip' in COPYCLIP stand for? I know what it does, but is it trying to say 'COPY to the CLIPboard'? The term 'clip' throws me off. 'Clip' sounds more like a removal process.
When you load an object enabler, it is loaded for the session, not the active drawing. So when the object enabler calls for something to be done (like copying data along with drawing entities to another drawing) then all that information goes with it. Not to say thats your problem, though - you could be dealing with rogue annotation scales, REGAPPs, DGN linetypes, yadda yadda yadda...
You can try uninstalling the object enabler, or fiddling with registry settings to prevent it loading. That might be the reason why the other user doesn't experience problems.
When purging there are *two* toggles - what can be purged, and what can't. The latter frequently gets ignored despite its usefulness in tracking down why certain things cannot be purged.
