In Autocad 2014 I can't seem to get the same properties when I choose a dimension as I have been with all previous vertions. It does not have any of the option such as text height, Tollerance, Precision etc. Is this new for 14?
Welcome to the forums.
The 2014 Properties palette should behave the same as it has in recent versions. Just to be clear, this is the main Properties palette, not Quick Properties .... right?
Did you happen to run a registry cleaner recently, or uninstall Autodesk360?
No to both registry and 360. Quick or main ? I right click and choose properties. PS Thanks for answering.
-Warren
Quick Properties is a smaller Properties window that can show information that you deem important. For the most part you have to go in a choose what it will show. This typically shows up when you highlite an entity if you have the feature turned On and does not need any additonal clicks.
The Properties window is standard and you cannot add or remove from it. Type PROPERTIES at the Command line and the window should Open and stay open.
Is each of the subheaders in the Properties window expanded? There should be a small black arrow at the end if each header line to expand if they are not.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
If I type in properties I do get the same window. It has the same information I had before which in not dot allow any changes. It has General, 3d Visualization, Plot style, View and Misc. only. If I choose a Dimension I should have text height, Arrow size etc. But I do not.
-W-
@Anonymous wrote:If I type in properties I do get the same window. It has the same information I had before which in not dot allow any changes. It has General, 3d Visualization, Plot style, View and Misc. only. If I choose a Dimension I should have text height, Arrow size etc. But I do not.
-W-
When you select an object, the Properties Palette should change to reflect the properties of that object. ie for Dimensions, General / 3D Visualization / PlotStyle etc should change to General / Misc / Lines& Arrows etc.
If this isn't happening, then as pendean said, something cleared those entries out of the Windows registry and you will have to Repair AutoCAD.
For Windows7; Start > Control Panel > Programs and Features > AutoCAD2014 > Repair / Reinstall
-W-
Have you seen this?
http://usa.autodesk.com/getdoc/id=TS22916
