I'm trying to edit line elevations (Start Z & End Z) and when I click in the field in the Properties palette it wont accept focus. Same for any other editable field. Any ideas? Autocad 2013.
No, not a locked layer 😞
Post a sample dwg file.
If you don't want to post the whole file (or CAN'T), then try wblocking out a few of these lines.
Then open your NEW file and confirm you get the same results. If you do get same results, post the dwg file for us.
Don Ireland
Engineering Design Technician
