AutoCAD 2013/2014/2015
TONYDELGIUDICE1018
Message 1 of 14 (460 Views)
program stopping
460 Views, 13 Replies
01-19-2013 01:27 PM
All of a sudden I got this window when starting AutoCAD:
"AutoCAD Application has Stopped working
A problem caused the program to stop working correctly.
Windows will close the program and notify you if a solution is available."
I'm using v2013 on a desktop with Windows 8
I have been using the program since I got this new system in November without a hitch
On sunday I had a nasty virus - Dell took it out everything was great
Today I had to uninstalled AutoCAD and re-installed it and it worked good.
After I closed it and went to open the application again I got the MESSAGE again
Distinguished Contributor
MariuszPL
Message 2 of 14 (454 Views)
Re: program stopping
01-19-2013 01:46 PM in reply to: TONYDELGIUDICE1018
Did you try to run AutoCAD in Windows 7 / Windows XP compability mode (Compability tab at Properties after right click on AutoCAD icon)?
TONYDELGIUDICE1018
Message 3 of 14 (450 Views)
01-19-2013 02:06 PM in reply to: TONYDELGIUDICE1018
I use to run this on VISTA with no problems
This computer came with windows 8 - Doesn't AutoDesk have an upgrade for W8
TONYDELGIUDICE1018
Message 4 of 14 (449 Views)
01-19-2013 02:08 PM in reply to: TONYDELGIUDICE1018
Does AutoDesk ever answer any of these questions
pendean
Message 5 of 14 (432 Views)
01-19-2013 07:25 PM in reply to: TONYDELGIUDICE1018
Win8 is not supported yet.
If you want Autodesk replies, buy a subscription.
Your issue may be resolved with a Windows System Restore back to a day or month it all worked, and/or a repair reinstall of AutoCAD.
Don't forget the first sentence of my reply here.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
TONYDELGIUDICE1018
Message 6 of 14 (423 Views)
01-20-2013 07:28 AM in reply to: pendean
Thanks - I have a subscription - I tried the restore last night to no avail - Woke up this morning and it's fine - Got me
pendean
Message 7 of 14 (402 Views)
01-21-2013 05:57 AM in reply to: TONYDELGIUDICE1018
The miracle of a Windows restart most likely :smileyhappy:
Employee
alison.gangler
Message 8 of 14 (380 Views)
01-22-2013 07:43 AM in reply to: pendean
Hi Tony,
I'm glad that the software is now working. If you encounter any issues in the future, please keep the following information in mind:
Note that Windows 8 uses the.NET Framework 4.5 which is incompatible with the 2013 products which were developed and released prior to the release of Windows 8 and are developed and tested on .NET 4.0.
Currently, there has not yet been an update issued to allow the 2013 products to also run on Windows 8.
Please find the policy for the 2013 products installed on Windows 8 at this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19048377&linkID=9240617
Cheers,
Alison
___________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Alison Gangler
IPG - ICP Install Engineer
TONYDELGIUDICE1018
Message 9 of 14 (342 Views)
01-28-2013 02:57 PM in reply to: alison.gangler
It stopped again - This is insane - I cannot operate my business without AutoCAD - I didn't know AutoCAD did not support Windows 8 - I asked AutoDesk about it and I get an email telling me what AutoCQAD Products are supported by Windows 8:
  • Autodesk 3ds Max 2013
  • Autodesk 3ds Max Design 2013
  • Autodesk Maya 2013
  • Autodesk MotionBuilder 2013
  • Autodesk Mudbox 2013
  • Autodesk Softimage 2013
  • Autodesk SketchBook Designer 2013
I don't see the most popular and most used product on this list do you?
How am I supposed to conduct business efficiently with an unreliable product and a company allows things like this to happen.
Ther is absolutely no one to turn to when companies like this have you over a barrel
But I blame myself for trusing AutoDesk
Alfred.NESWADBA
Message 10 of 14 (333 Views)
01-28-2013 03:19 PM in reply to: TONYDELGIUDICE1018
>> This is insane [...]
To be honest: you are using AutoCAD 2013 in an environment it's not supposed to work and you call it "unreliable"?
If you buy a car and jump off the cliffs do you ask then why the car does not drive vertically down in a reliable mode? Is that insane?
If you need to work with AutoCAD then use the systems that AutoCAD is built for and tested on (>>>AutoCAD 2013 system requirements<<<).
Win8 was released later than AutoCAD 2013, so you can't expect AutoCAD to run on an os that was not available when AutoCAD 2013 was released. There may be an update, but for now there is no one (and I guess it's a lot of work to get it stable on Win8, so better wait more time but be more safe then too)
- alfred -
Alfred NESWADBA
