Is it possible to get the license server information anywhere in the Moldflow advisor 2015 interface. We used to be able to get this info from the Product Information button in the About section in earlier releases; but this option is not found in MFA 2015.
Solved by avto. Go to Solution.
From within Moldlfow Adviser 2015 interface, unfortunately you can not obtain the license server information. However, you can get your license server status form your Moldflow workstation as follows:
1. Install Autodesk Network License Manager on your Moldflow workstation
2. Create a simple batch file with following content
@echo off
cd “C:\Program Files\Autodesk Network License Manager”
.\lmutil.exe lmstat -a -c "C:\Program Files\Autodesk\Simulation Moldflow Adviser 2015\LICPATH.lic" > C:\serverStat.txt
notepad C:\serverStat.txt
3. Execute your batch file and you should see the license server status enquiry in a notepad file (C:\serverStat.txt).
