I had a macrotext made for a custum made button that changes the properties (layer, color, linetype etc etc) by selecting the objects I want to change.
It worked till autocad 2013. Now with autocad 2014 not anymore. The macrotext is:
^C^Cselect;au;\_.change;Pr;LA;00_AANZ-50;LT;CONTINUOUS;COLOR;BYLAYER;;
When I click the button I can select the objects. After selection I close with an enter and all the changes will be executed in one time..
The 'au' option is not working anymore.
Can someone help me out.
Gr. Joopvz
Try doing the equivalent of the macro on the command line. Do you get any unexpected prompts or messages?
I think it may be that PICKFIRST has been set to 0 (off). (If this is the case, and you would like to avoid this happening again, you can add setting that to the macro.)
