Anyone having problems after installing SP2?
For the Rrecord this is what it looks like after un-installing SP2...
Solved by dan908. Go to Solution.
The official hotfix link is updated:
Hello
Some people are happy with the SP 2 + eventually 2 Hotfix : BigFont & Layout Order moving
Some are unhappy, so please uninstall the SP 2 and keep the SP 1 ...
Patrice BRAUD
Uninstall SP2 and you should be able to open. I was having this issue as well and uninstalling SP2 fixed the issue.
The link to the hotfix is not working. http://knowledge.autodesk.com/support/autocad/downloads/caas/downloads/content/autodesk-C2-AE-autoca...
Can I get the hotfix for this text issue? I am having the same problem.
Thanks.
Susan
I have been experiencing these same issues of objects shifting with 3D drawings: objects appear to be missing but are reloacted to a different location with the reference points still intact where they "should" be. There appears to be no relation to particular blocks, scale properties, etc. It is completely random and happens when I reopen the file. The best way to explain it is if someone physically shook the drawing and the pieces were rattled around. I have only noticed this happening after the SP2 update and has been causing me a great deal of grief, confusion, and productive time wasted. I will be uninstalling the SP2 update since it has cost me too much in terms of deadlines and the 3D drawings I deal with are far too complex and technical to keep re-doing these errors. I will be hesitant to install any further update or patch unless this issue can be properly addressed and explained other than with an excuse of "we don't know".
