AutoCAD Forum
Problems with AutoCAD 2015 Service Pack 2
29 REPLIES 29
Message 1 of 30
MBCT
3781 Views, 29 Replies
Anyone having problems after installing SP2?
For the Rrecord this is what it looks like after un-installing SP2...
29 REPLIES 29
Message 21 of 30
gaop
in reply to: MBCT
Message 22 of 30
Jason-Cad-123
in reply to: nestly2
Just installed SP2 on 2 autocad 2015. Now I am unable to open drawings.
Message 23 of 30
Jason-Cad-123
in reply to: dan908
Yes I have found after installing SP2 for AutoCAD 2015. I can not opening drawings cad just locks up
Message 24 of 30
braudpat
in reply to: Jason-Cad-123
Hello
Some people are happy with the SP 2 + eventually 2 Hotfix : BigFont & Layout Order moving
Some are unhappy, so please uninstall the SP 2 and keep the SP 1 ...
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 25 of 30
info
Uninstall SP2 and you should be able to open. I was having this issue as well and uninstalling SP2 fixed the issue.
Message 26 of 30
susan.campbell
in reply to: dan908
The link to the hotfix is not working.  http://knowledge.autodesk.com/support/autocad/downloads/caas/downloads/content/autodesk-C2-AE-autoca...
Can I get the hotfix for this text issue?  I am having the same problem.
Thanks.
Susan
Message 27 of 30
Sorry.  I just saw the corrected link.  I am good.
Message 28 of 30
emailmott
in reply to: MBCT
I have been experiencing these same issues of objects shifting with 3D drawings: objects appear to be missing but are reloacted to a different location with the reference points still intact where they "should" be.  There appears to be no relation to particular blocks, scale properties, etc.  It is completely random and happens when I reopen the file.  The best way to explain it is if someone physically shook the drawing and the pieces were rattled around.  I have only noticed this happening after the SP2 update and has been causing me a great deal of grief, confusion, and productive time wasted.  I will be uninstalling the SP2 update since it has cost me too much in terms of deadlines and the 3D drawings I deal with are far too complex and technical to keep re-doing these errors.  I will be hesitant to install any further update or patch unless this issue can be properly addressed and explained other than with an excuse of "we don't know".
Message 29 of 30
kudryavcevrm
in reply to: MBCT
Message 30 of 30
in reply to: dan908
"Page not found."
”Boost
