AutoCAD 2013/2014/2015
Active Member
0 Kudos
Post 1 of 3
Accepted Solution
Problems with AutoCAD 2014
366 Views, 2 Replies
07-19-2013 12:36 PM
Hay, lately I have been having several problems with AutoCAD 2014.
1) When I make a line-I used to be able to type in the start point, angle, length, and end point.  Now I make a line I don’t have that option.  Furthermore I hover the muse over line and try to make an extension of for example 3.5" from the start point after I hit enter it will put the start point at what i think is a random point of the screen.  How can get the options back.
2) When i presspull an object-When i would presspull an object i would (with my mouse) drag it in the direction that wanted it to go hen type in the lengh.  So if i were to pull it to the right then type in the number it would go to the right.  now it goes let no matter what.  How can change that
Have you possibly turned off dynamic input? Click dynamic icon on bottom left of screen or press F12 to toggle on or off. Right clicking on Dynamic icon and selecting settings offers many more input options etc.
*Expert Elite*
461 Kudos
Post 2 of 3
Re: Problems with AutoCAD 2014
07-19-2013 08:24 PM in reply to: simskorn
Jay
C3D 2014 SP2
Win 7 Professional 64 Bit
Active Member
0 Kudos
Post 3 of 3
07-19-2013 09:35 PM in reply to: Jay_B
Thank you so much that did the trick.
Post to the Community
New Post
